Radds - Graficzny wyświetlacz
lukasz51
Postautor: lukasz51 » 05 lip 2015, 16:10
od kilku dni próbuje podłączyć wyświetlacz graficzny do elektroniki RADDS. Podłączenie tak jak na zdjęciu.
https://github.com/luc-github/DUE-RADDS ... g?raw=true
Wszystko skonfigurowane tak jak na stronie. W repertierze zmodyfikowane pliki uiconfig.h i configuration.h
https://github.com/luc-github/DUE-RADDS-GLCD
Kable sprawdzałem seki razy, krótkie podłączone prawidło. Jedyne co wyświetla się na LCD to jakieś dziwne znaczki, lub mrówki.
Może ktoś z kolegów podpowie co może być nie tak.
    This file is part of Repetier-Firmware.
    Repetier-Firmware is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    Repetier-Firmware is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
/**************** READ FIRST ************************
   This configuration file was created with the configuration tool. For that
   reason, it does not contain the same informations as the original Configuration.h file.
   It misses the comments and unused parts. Open this file file in the config tool
   to see and change the data. You can also upload it to newer/older versions. The system
   will silently add new options, so compilation continues to work.
   This file is optimized for version 0.92
   generator: http://www.repetier.com/firmware/v092/
   If you are in doubt which named functions use which pins on your board, please check the
   pins.h for the used name->pin assignments and your board documentation to verify it is
   as you expect.
#define NUM_EXTRUDER 1
#define MOTHERBOARD 402
#define RFSERIAL Serial
#include "pins.h"
// ################## EDIT THESE SETTINGS MANUALLY ################
// ################ END MANUAL SETTINGS ##########################
#define FAN_BOARD_PIN -1
//#define EXTERNALSERIAL  use Arduino serial library instead of build in. Requires more ram, has only 63 byte input buffer.
// Uncomment the following line if you are using arduino compatible firmware made for Arduino version earlier then 1.0
// If it is incompatible you will get compiler errors about write functions not beeing compatible!
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL  -1
#define BLUETOOTH_BAUD  115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 80
#define YAXIS_STEPS_PER_MM 80
#define ZAXIS_STEPS_PER_MM 80
#define EXTRUDER_FAN_COOL_TEMP 50
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define DECOUPLING_TEST_MAX_HOLD_VARIANCE 20
#define DECOUPLING_TEST_MIN_TEMP_RISE 1
#define KILL_IF_SENSOR_DEFECT 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_START_COMMANDS ""
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 370
#define EXT0_TEMPSENSOR_TYPE 1
#define EXT0_TEMPSENSOR_PIN TEMP_0_PIN
#define EXT0_HEATER_PIN HEATER_0_PIN
#define EXT0_STEP_PIN ORIG_E0_STEP_PIN
#define EXT0_DIR_PIN ORIG_E0_DIR_PIN
#define EXT0_INVERSE 0
#define EXT0_ENABLE_PIN E0_ENABLE_PIN
#define EXT0_ENABLE_ON 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_MAX_START_FEEDRATE 20
#define EXT0_MAX_ACCELERATION 5000
#define EXT0_HEAT_MANAGER 3
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_INTEGRAL_DRIVE_MAX 230
#define EXT0_PID_INTEGRAL_DRIVE_MIN 40
#define EXT0_PID_PGAIN_OR_DEAD_TIME 7
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_ADVANCE_BACKLASH_STEPS 0
#define EXT0_WAIT_RETRACT_TEMP 150
#define EXT0_WAIT_RETRACT_UNITS 0
#define EXT0_SELECT_COMMANDS ""
#define EXT0_DESELECT_COMMANDS ""
#define EXT0_EXTRUDER_COOLER_PIN -1
#define EXT0_EXTRUDER_COOLER_SPEED 255
#define EXT0_DECOUPLE_TEST_PERIOD 12000
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_LONG_LENGTH 13
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define RETRACTION_UNDO_EXTRA_LENGTH 0
#define RETRACTION_UNDO_EXTRA_LONG_LENGTH 0
#define RETRACTION_UNDO_SPEED 20
#define FILAMENTCHANGE_X_POS 0
#define FILAMENTCHANGE_Y_POS 0
#define FILAMENTCHANGE_Z_ADD  2
#define FILAMENTCHANGE_REHOME 1
#define FILAMENTCHANGE_SHORTRETRACT 5
#define FILAMENTCHANGE_LONGRETRACT 50
#define JAM_STEPS 220
#define JAM_SLOWDOWN_STEPS 320
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define RETRACT_DURING_HEATUP true
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define NUM_TEMPS_USERTHERMISTOR0 0
#define USER_THERMISTORTABLE0 {}
#define NUM_TEMPS_USERTHERMISTOR1 0
#define USER_THERMISTORTABLE1 {}
#define NUM_TEMPS_USERTHERMISTOR2 0
#define USER_THERMISTORTABLE2 {}
#define GENERIC_THERM_VREF 5
#define GENERIC_THERM_NUM_ENTRIES 33
#define HEATER_PWM_SPEED 0
// ############# Heated bed configuration ########################
#define HAVE_HEATED_BED 0
#define HEATED_BED_MAX_TEMP 120
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_SENSOR_TYPE 1
#define HEATED_BED_SENSOR_PIN TEMP_1_PIN
#define HEATED_BED_HEATER_PIN HEATER_1_PIN
#define HEATED_BED_SET_INTERVAL 5000
#define HEATED_BED_HEAT_MANAGER 0
#define HEATED_BED_PID_INTEGRAL_DRIVE_MAX 255
#define HEATED_BED_PID_INTEGRAL_DRIVE_MIN 80
#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
#define HEATED_BED_PID_IGAIN   33
#define HEATED_BED_PID_DGAIN 290
#define HEATED_BED_PID_MAX 255
#define HEATED_BED_DECOUPLE_TEST_PERIOD 300000
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
#define MIN_DEFECT_TEMPERATURE -10
#define MAX_DEFECT_TEMPERATURE 290
// ################ Endstop configuration #####################
#define ENDSTOP_PULLUP_X_MIN true
#define ENDSTOP_X_MIN_INVERTING true
#define MIN_HARDWARE_ENDSTOP_X true
#define ENDSTOP_PULLUP_Y_MIN true
#define ENDSTOP_Y_MIN_INVERTING true
#define MIN_HARDWARE_ENDSTOP_Y true
#define ENDSTOP_PULLUP_Z_MIN true
#define ENDSTOP_Z_MIN_INVERTING true
#define MIN_HARDWARE_ENDSTOP_Z true
#define ENDSTOP_PULLUP_X_MAX true
#define ENDSTOP_X_MAX_INVERTING false
#define MAX_HARDWARE_ENDSTOP_X false
#define ENDSTOP_PULLUP_Y_MAX true
#define ENDSTOP_Y_MAX_INVERTING false
#define MAX_HARDWARE_ENDSTOP_Y false
#define ENDSTOP_PULLUP_Z_MAX true
#define ENDSTOP_Z_MAX_INVERTING false
#define MAX_HARDWARE_ENDSTOP_Z false
#define max_software_endstop_r true
#define min_software_endstop_x false
#define min_software_endstop_y false
#define min_software_endstop_z false
#define max_software_endstop_x true
#define max_software_endstop_y true
#define max_software_endstop_z true
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_X_RETEST_REDUCTION_FACTOR 3
#define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 3
#define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 3
#define ENDSTOP_X_BACK_ON_HOME 1
#define ENDSTOP_Y_BACK_ON_HOME 1
#define ENDSTOP_Z_BACK_ON_HOME 0
#define ALWAYS_CHECK_ENDSTOPS 1
// ################# XYZ movements ###################
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 120
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_CORRECTION 0
#define DISTORTION_CORRECTION_POINTS 5
#define DISTORTION_CORRECTION_R 100
#define DISTORTION_PERMANENT 1
#define DISTORTION_UPDATE_FREQUENCY 15
#define DISTORTION_START_DEGRADE 0.5
#define DISTORTION_END_HEIGHT 1
#define DISTORTION_EXTRAPOLATE_CORNERS 0
// ##                           Movement settings                                          ##
#define FEATURE_BABYSTEPPING 1
#define BABYSTEP_MULTIPLICATOR 1
#define DELTA_SEGMENTS_PER_SECOND_PRINT 180 // Move accurate setting for print moves
#define DELTA_SEGMENTS_PER_SECOND_MOVE 70 // Less accurate setting for other moves
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define DELTASEGMENTS_PER_PRINTLINE 24
#define STEPPER_INACTIVE_TIME 360L
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 2
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 2
#define HOMING_ORDER HOME_ORDER_ZXY
#define ZHOME_MIN_TEMPERATURE 0
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define ENABLE_BACKLASH_COMPENSATION 0
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define STEP_DOUBLER_FREQUENCY 80000
#define ALLOW_QUADSTEPPING 1
#define DOUBLE_STEP_DELAY 0 // time in microseconds
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 1000
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1000
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 100
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 1000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1000
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 100
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define PRINTLINE_CACHE_SIZE 16
#define MOVE_CACHE_LOW 10
#define LOW_TICKS_PER_MOVE 250000
#define FEATURE_TWO_XSTEPPER 0
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define X2_ENABLE_PIN E1_ENABLE_PIN
#define FEATURE_TWO_YSTEPPER 0
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define Y2_ENABLE_PIN E1_ENABLE_PIN
#define FEATURE_TWO_ZSTEPPER 0
#define Z2_STEP_PIN   ORIG_E1_STEP_PIN
#define Z2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z2_ENABLE_PIN E1_ENABLE_PIN
#define FEATURE_DITTO_PRINTING 0
#define USE_ADVANCE 0
#define ENABLE_QUADRATIC_ADVANCE 0
// ################# Misc. settings ##################
#define BAUDRATE 115200
#define ENABLE_POWER_ON_STARTUP 1
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define WAITING_IDENTIFIER "wait"
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#define PS_ON_PIN ORIG_PS_ON_PIN
/* ======== Servos =======
Control the servos with
M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
Servos are controlled by a pulse width normally between 500 and 2500 with 1500ms in center position. 0 turns servo off.
WARNING: Servos can draw a considerable amount of current. Make sure your system can handle this or you may risk your hardware!
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS  -1
#define SERVO1_NEUTRAL_POS  -1
#define SERVO2_NEUTRAL_POS  -1
#define SERVO3_NEUTRAL_POS  -1
#define UI_SERVO_CONTROL 0
#define FAN_KICKSTART_TIME  200
        #define FEATURE_WATCHDOG 0
// #################### Z-Probing #####################
#define FEATURE_Z_PROBE 0
#define Z_PROBE_BED_DISTANCE 10
#define Z_PROBE_PIN -1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_WAIT_BEFORE_TEST 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 1
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 40
#define Z_PROBE_START_SCRIPT ""
#define Z_PROBE_FINISHED_SCRIPT ""
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 160
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#ifndef SDSUPPORT  // Some boards have sd support on board. These define the values already in pins.h
#define SDSUPPORT 1
#define SDCARDDETECT 41
#define SDCARDDETECTINVERTED 0
#endif
#define SD_EXTENDED_DIR 1 /** Show extended directory including file length. Don't use this with Pronterface! */
#define SD_RUN_ON_STOP ""
#define SD_STOP_HEATER_AND_MOTORS_ON_STOP 1
#define ARC_SUPPORT 1
#define FEATURE_MEMORY_POSITION 1
#define FEATURE_CHECKSUM_FORCED 0
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER UICONFIG_CONTROLLER
#define UI_LANGUAGE 9
#define UI_PRINTER_NAME "RepRap"
#define UI_PRINTER_COMPANY "Home made"
#define UI_PAGES_DURATION 4000
#define UI_ANIMATION 1
#define UI_SPEEDDEPENDENT_POSITIONING 0
#define UI_DISABLE_AUTO_PAGESWITCH 1
#define UI_AUTORETURN_TO_MENU_AFTER 30000
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_FIRST_REPEAT 500
#define UI_KEY_REDUCE_REPEAT 50
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define CASE_LIGHT_DEFAULT_ON 1
#define UI_START_SCREEN_DELAY 1000
#define UI_DYNAMIC_ENCODER_SPEED 1
Beeper sound definitions for short beeps during key actions
and longer beeps for important actions.
Parameter is delay in microseconds and the secons is the number of repetitions.
Values must be in range 1..255
#define BEEPER_SHORT_SEQUENCE 2,2
#define BEEPER_LONG_SEQUENCE 8,8
#define UI_SET_PRESET_HEATED_BED_TEMP_PLA 60
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA   190
#define UI_SET_PRESET_HEATED_BED_TEMP_ABS 110
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS   240
#define UI_SET_MIN_HEATED_BED_TEMP  30
#define UI_SET_MAX_HEATED_BED_TEMP 120
#define UI_SET_MIN_EXTRUDER_TEMP   170
#define UI_SET_MAX_EXTRUDER_TEMP   260
#define UI_SET_EXTRUDER_FEEDRATE 2
#define UI_SET_EXTRUDER_RETRACT_DISTANCE 3
#define NUM_MOTOR_DRIVERS 0
#endif
/* Below you will find the configuration string, that created this Configuration.h
========== Start configuration string ==========
    "editMode": 2,
    "processor": 1,
    "baudrate": 115200,
    "bluetoothSerial": -1,
    "bluetoothBaudrate": 115200,
    "xStepsPerMM": 80,
    "yStepsPerMM": 80,
    "zStepsPerMM": 80,
    "xInvert": 0,
    "xInvertEnable": 0,
    "eepromMode": 1,
    "yInvert": 0,
    "yInvertEnable": 0,
    "zInvert": 0,
    "zInvertEnable": 0,
    "extruder": [
            "id": 0,
            "heatManager": 3,
            "pidDriveMin": 40,
            "pidDriveMax": 230,
            "pidMax": 255,
            "sensorType": 1,
            "sensorPin": "TEMP_0_PIN",
            "heaterPin": "HEATER_0_PIN",
            "maxFeedrate": 50,
            "startFeedrate": 20,
            "invert": "0",
            "invertEnable": "0",
            "acceleration": 5000,
            "watchPeriod": 1,
            "pidP": 7,
            "pidI": 2,
            "pidD": 40,
            "advanceK": 0,
            "advanceL": 0,
            "waitRetractTemp": 150,
            "waitRetractUnits": 0,
            "waitRetract": 0,
            "stepsPerMM": 370,
            "coolerPin": -1,
            "coolerSpeed": 255,
            "selectCommands": "",
            "deselectCommands": "",
            "xOffset": 0,
            "yOffset": 0,
            "zOffset": 0,
            "xOffsetSteps": 0,
            "yOffsetSteps": 0,
            "zOffsetSteps": 0,
            "stepper": {
                "name": "Extruder 0",
                "step": "ORIG_E0_STEP_PIN",
                "dir": "ORIG_E0_DIR_PIN",
                "enable": "E0_ENABLE_PIN"
            "advanceBacklashSteps": 0,
            "decoupleTestPeriod": 12,
            "jamPin": -1,
            "jamPullup": "0"
    "uiLanguage": 0,
    "uiController": 0,
    "xMinEndstop": 1,
    "yMinEndstop": 1,
    "zMinEndstop": 1,
    "xMaxEndstop": 0,
    "yMaxEndstop": 0,
    "zMaxEndstop": 0,
    "motherboard": 402,
    "driveSystem": 0,
    "xMaxSpeed": 200,
    "xHomingSpeed": 40,
    "xTravelAcceleration": 1000,
    "xPrintAcceleration": 1000,
    "yMaxSpeed": 200,
    "yHomingSpeed": 40,
    "yTravelAcceleration": 1000,
    "yPrintAcceleration": 1000,
    "zMaxSpeed": 2,
    "zHomingSpeed": 2,
    "zTravelAcceleration": 100,
    "zPrintAcceleration": 100,
    "xMotor": {
        "name": "X motor",
        "step": "ORIG_X_STEP_PIN",
        "dir": "ORIG_X_DIR_PIN",
        "enable": "ORIG_X_ENABLE_PIN"
    "yMotor": {
        "name": "Y motor",
        "step": "ORIG_Y_STEP_PIN",
        "dir": "ORIG_Y_DIR_PIN",
        "enable": "ORIG_Y_ENABLE_PIN"
    "zMotor": {
        "name": "Z motor",
        "step": "ORIG_Z_STEP_PIN",
        "dir": "ORIG_Z_DIR_PIN",
        "enable": "ORIG_Z_ENABLE_PIN"
    "enableBacklash": "0",
    "backlashX": 0,
    "backlashY": 0,
    "backlashZ": 0,
    "stepperInactiveTime": 360,
    "maxInactiveTime": 0,
    "xMinPos": 0,
    "yMinPos": 0,
    "zMinPos": 0,
    "xLength": 200,
    "yLength": 200,
    "zLength": 120,
    "alwaysCheckEndstops": "1",
    "disableX": "0",
    "disableY": "0",
    "disableZ": "0",
    "disableE": "0",
    "xHomeDir": "-1",
    "yHomeDir": "-1",
    "zHomeDir": "-1",
    "xEndstopBack": 1,
    "yEndstopBack": 1,
    "zEndstopBack": 0,
    "deltaSegmentsPerSecondPrint": 180,
    "deltaSegmentsPerSecondTravel": 70,
    "deltaDiagonalRod": 445,
    "deltaHorizontalRadius": 209.25,
    "deltaAlphaA": 210,
    "deltaAlphaB": 330,
    "deltaAlphaC": 90,
    "deltaDiagonalCorrA": 0,
    "deltaDiagonalCorrB": 0,
    "deltaDiagonalCorrC": 0,
    "deltaMaxRadius": 150,
    "deltaFloorSafetyMarginMM": 15,
    "deltaRadiusCorrA": 0,
    "deltaRadiusCorrB": 0,
    "deltaRadiusCorrC": 0,
    "deltaXOffsetSteps": 0,
    "deltaYOffsetSteps": 0,
    "deltaZOffsetSteps": 0,
    "deltaSegmentsPerLine": 24,
    "stepperHighDelay": 0,
    "directionDelay": 0,
    "stepDoublerFrequency": 80000,
    "allowQuadstepping": "1",
    "doubleStepDelay": 0,
    "maxJerk": 20,
    "maxZJerk": 0.3,
    "moveCacheSize": 16,
    "moveCacheLow": 10,
    "lowTicksPerMove": 250000,
    "enablePowerOnStartup": "1",
    "echoOnExecute": "1",
    "sendWaits": "1",
    "ackWithLineNumber": "1",
    "killMethod": 1,
    "useAdvance": "0",
    "useQuadraticAdvance": "0",
    "powerInverting": 0,
    "mirrorX": 0,
    "mirrorXMotor": {
        "name": "Extruder 1",
        "step": "ORIG_E1_STEP_PIN",
        "dir": "ORIG_E1_DIR_PIN",
        "enable": "E1_ENABLE_PIN"
    "mirrorY": 0,
    "mirrorYMotor": {
    "mirrorZ": 0,
    "mirrorZMotor": {
    "dittoPrinting": "0",
    "featureServos": "0",
    "servo0Pin": 11,
    "servo1Pin": -1,
    "servo2Pin": -1,
    "servo3Pin": -1,
    "featureWatchdog": "0",
    "hasHeatedBed": "0",
    "enableZProbing": "0",
    "extrudeMaxLength": 160,
    "homeOrder": "HOME_ORDER_ZXY",
    "featureController": 0,
    "uiPrinterName": "RepRap",
    "uiPrinterCompany": "Home made",
    "uiPagesDuration": 4000,
    "uiAnimation": "1",
    "uiDisablePageswitch": "1",
    "uiAutoReturnAfter": 30000,
    "featureKeys": "0",
    "uiEncoderSpeed": 1,
    "uiReverseEncoder": "0",
    "uiKeyBouncetime": 10,
    "uiKeyFirstRepeat": 500,
    "uiKeyReduceRepeat": 50,
    "uiKeyMinRepeat": 50,
    "featureBeeper": "0",
    "uiPresetBedTempPLA": 60,
    "uiPresetBedABS": 110,
    "uiPresetExtruderPLA": 190,
    "uiPresetExtruderABS": 240,
    "uiMinHeatedBed": 30,
    "uiMaxHeatedBed": 120,
    "uiMinEtxruderTemp": 170,
    "uiMaxExtruderTemp": 260,
    "uiExtruderFeedrate": 2,
    "uiExtruderRetractDistance": 3,
    "uiSpeeddependentPositioning": "0",
    "maxBedTemperature": 120,
    "bedSensorType": 1,
    "bedSensorPin": "TEMP_1_PIN",
    "bedHeaterPin": "HEATER_1_PIN",
    "bedHeatManager": 0,
    "bedUpdateInterval": 5000,
    "bedPidDriveMin": 80,
    "bedPidDriveMax": 255,
    "bedPidP": 196,
    "bedPidI": 33,
    "bedPidD": 290,
    "bedPidMax": 255,
    "bedDecoupleTestPeriod": 300,
    "caseLightPin": -1,
    "caseLightDefaultOn": "1",
    "bedSkipIfWithin": 3,
    "gen1T0": 25,
    "gen1R0": 100000,
    "gen1Beta": 4036,
    "gen1MinTemp": -20,
    "gen1MaxTemp": 300,
    "gen1R1": 0,
    "gen1R2": 4700,
    "gen2T0": 25,
    "gen2R0": 100000,
    "gen2Beta": 4036,
    "gen2MinTemp": -20,
    "gen2MaxTemp": 300,
    "gen2R1": 0,
    "gen2R2": 4700,
    "gen3T0": 25,
    "gen3R0": 100000,
    "gen3Beta": 4036,
    "gen3MinTemp": -20,
    "gen3MaxTemp": 300,
    "gen3R1": 0,
    "gen3R2": 4700,
    "userTable0": {
        "r1": 0,
        "r2": 4700,
        "temps": [
    "userTable1": {
        "r1": 0,
        "r2": 4700,
        "temps": [
    "userTable2": {
        "r1": 0,
        "r2": 4700,
        "temps": [
    "tempHysteresis": 0,
    "pidControlRange": 20,
    "skipM109Within": 2,
    "extruderFanCoolTemp": 50,
    "minTemp": 150,
    "maxTemp": 275,
    "minDefectTemp": -10,
    "maxDefectTemp": 290,
    "arcSupport": "1",
    "featureMemoryPositionWatchdog": "1",
    "forceChecksum": "0",
    "sdExtendedDir": "1",
    "featureFanControl": "1",
    "fanPin": "ORIG_FAN_PIN",
    "scalePidToMax": 0,
    "zProbePin": -1,
    "zProbeBedDistance": 10,
    "zProbePullup": "0",
    "zProbeOnHigh": "0",
    "zProbeXOffset": 0,
    "zProbeYOffset": 0,
    "zProbeWaitBeforeTest": "0",
    "zProbeSpeed": 2,
    "zProbeXYSpeed": 150,
    "zProbeHeight": 40,
    "zProbeStartScript": "",
    "zProbeFinishedScript": "",
    "featureAutolevel": "1",
    "zProbeX1": 20,
    "zProbeY1": 20,
    "zProbeX2": 160,
    "zProbeY2": 20,
    "zProbeX3": 100,
    "zProbeY3": 160,
    "zProbeSwitchingDistance": 1,
    "zProbeRepetitions": 1,
    "sdSupport": "0",
    "sdCardDetectPin": -1,
    "sdCardDetectInverted": "0",
    "uiStartScreenDelay": 1000,
    "xEndstopBackMove": 5,
    "yEndstopBackMove": 5,
    "zEndstopBackMove": 2,
    "xEndstopRetestFactor": 3,
    "yEndstopRetestFactor": 3,
    "zEndstopRetestFactor": 3,
    "xMinPin": "ORIG_X_MIN_PIN",
    "yMinPin": "ORIG_Y_MIN_PIN",
    "zMinPin": "ORIG_Z_MIN_PIN",
    "xMaxPin": "ORIG_X_MAX_PIN",
    "yMaxPin": "ORIG_Y_MAX_PIN",
    "zMaxPin": "ORIG_Z_MAX_PIN",
    "deltaHomeOnPower": "0",
    "fanBoardPin": -1,
    "heaterPWMSpeed": 0,
    "featureBabystepping": "1",
    "babystepMultiplicator": 1,
    "pdmForHeater": "0",
    "pdmForCooler": "0",
    "psOn": "ORIG_PS_ON_PIN",
    "mixingExtruder": "0",
    "decouplingTestMaxHoldVariance": 20,
    "decouplingTestMinTempRise": 1,
    "featureAxisComp": "0",
    "axisCompTanXY": 0,
    "axisCompTanXZ": 0,
    "axisCompTanYZ": 0,
    "retractOnPause": 2,
    "pauseStartCommands": "",
    "pauseEndCommands": "",
    "distortionCorrection": "0",
    "distortionCorrectionPoints": 5,
    "distortionCorrectionR": 100,
    "distortionPermanent": "1",
    "distortionUpdateFrequency": 15,
    "distortionStartDegrade": 0.5,
    "distortionEndDegrade": 1,
    "distortionExtrapolateCorners": "0",
    "sdRunOnStop": "",
    "sdStopHeaterMotorsOnStop": "1",
    "featureRetraction": "1",
    "autoretractEnabled": "0",
    "retractionLength": 3,
    "retractionLongLength": 13,
    "retractionSpeed": 40,
    "retractionZLift": 0,
    "retractionUndoExtraLength": 0,
    "retractionUndoExtraLongLength": 0,
    "retractionUndoSpeed": 20,
    "filamentChangeXPos": 0,
    "filamentChangeYPos": 0,
    "filamentChangeZAdd": 2,
    "filamentChangeRehome": 1,
    "filamentChangeShortRetract": 5,
    "filamentChangeLongRetract": 50,
    "fanKickstart": 200,
    "servo0StartPos": -1,
    "servo1StartPos": -1,
    "servo2StartPos": -1,
    "servo3StartPos": -1,
    "uiDynamicEncoderSpeed": "1",
    "uiServoControl": 0,
    "killIfSensorDefect": "0",
    "jamSteps": 220,
    "jamSlowdownSteps": 320,
    "jamSlowdownTo": 70,
    "jamErrorSteps": 500,
    "jamMinSteps": 10,
    "jamAction": 1,
    "primaryPort": 1,
    "numMotorDrivers": 0,
    "motorDrivers": [
            "t": "None",
            "s": "",
            "invertDirection": "0",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1
            "t": "None",
            "s": "",
            "stepsPerMM": 100,
            "speed": 10,
            "dirPin": -1,
            "stepPin": -1,
            "enablePin": -1
    "manualConfig": "",
    "zHomeMinTemperature": 0,
    "zHomeXPos": 999999,
    "zHomeYPos": 999999,
    "zHomeHeatHeight": 20,
    "zHomeHeatAll": "1",
    "hasMAX6675": false,
    "hasMAX31855": false,
    "hasGeneric1": false,
    "hasGeneric2": false,
    "hasGeneric3": false,
    "hasUser0": false,
    "hasUser1": false,
    "hasUser2": false,
    "numExtruder": 1,
    "version": 92.3,
    "primaryPortName": "Serial"
========== End configuration string ==========
/* ===================== IMPORTANT ========================
The LCD and Key support is new. I tested everything as good as possible,
but some combinations may not work as supposed.
The I2C methods rely on a stable I2C connection. Noise may cause wrong signals
which can cause the firmware to freeze.
The ui adds quite some code, so AVRs with 64kB ram (Sanguino, Gen6) can not handle all features
of the firmware at the same time. You have to disable some features to gain the
ram needed. What should work:
- No sd card - the sd card code is quite large.
- No keys attached - The longest part is the menu handling.
- EEPROM_MODE 0 .
Currently supported hardware:
*** Displays ***
- direct connected lcd with 4 data lines
- connected via i2c
*** Keys ***
- rotary encoder
- push button
- key matrix up to 4x4
- rotary encoder via i2c (only slow turns are captured correct)
- push button via i2c
*** Buzzer ***
- directly connected, high = on
- connected via i2c, low = on
#ifndef _ui_config_h
#define _ui_config_h
/** While the ascii chars are all the same, the driver have different charsets
for special chars used in different countries. The charset allows to fix for
this problem. If characters look wrong, try a different charset. If nothing
works, use the ascii charset 0 as fallback. Not the nicest for everything but working!
0 = ASCII fallback
1 = Default works on most displays. This has some japanese chars in charset
2 = Alternative charset with more european chars
#define UI_DISPLAY_CHARSET 2
/** Select type of beeper
0 = none
1 = Piezo connected to pin
2 = Piezo connected to a pin over I2C
#ifndef BEEPER_TYPE
#define BEEPER_TYPE 1
#define BEEPER_TYPE_INVERTING false
#endif
#if BEEPER_TYPE==1 && !defined(BEEPER_PIN)
#define BEEPER_PIN 41
#endif
#if BEEPER_TYPE==2
#define BEEPER_ADDRESS 0x40 // I2C address of the chip with the beeper pin
#define BEEPER_PIN _BV(7)  // Bit value for pin 8
#define COMPILE_I2C_DRIVER  // We need the I2C driver as we are using i2c
#endif
What display type do you use?
0 = No display
1 = LCD Display with 4 bit data bus
2 = LCD Display with 8 bit data bus (currently not implemented, fallback to 1)
3 = LCD Display with I2C connection, 4 bit mode
4 = Use the slower LiquiedCrystal library bundled with arduino.
    IMPORTANT: You need to uncomment the LiquidCrystal include in Repetier.pde for it to work.
               If you have Sanguino and want to use the library, you need to have Arduino 023 or older. (13.04.2012)
5 = U8G supported display
#define UI_DISPLAY_TYPE 5
#if UI_DISPLAY_TYPE == DISPLAY_U8G // Special case for graphic displays
#define U8GLIB_ST7920 // Currently only this display from u8g lib is included.
#define UI_LCD_WIDTH 128
#define UI_LCD_HEIGHT 64
//select font size
#define UI_FONT_6X10 //default font
#ifdef UI_FONT_6X10
#define UI_FONT_WIDTH 6
#define UI_FONT_HEIGHT 10
#define UI_FONT_SMALL_HEIGHT 7
#define UI_FONT_DEFAULT repetier_6x10
#define UI_FONT_SMALL repetier_5x7
#define UI_FONT_SMALL_WIDTH 5 //smaller font for status display
#define UI_ANIMATION false  // Animations are too slow
#endif
//calculate rows and cols available with current font
#define UI_COLS (UI_LCD_WIDTH/UI_FONT_WIDTH)
#define UI_ROWS (UI_LCD_HEIGHT/UI_FONT_HEIGHT)
#define UI_DISPLAY_CHARSET 3
#else
/** Number of columns per row
Typical values are 16 and 20
#define UI_COLS 20
Rows of your display. 2 or 4
#define UI_ROWS 4
#endif // UI_DISPLAY_TYPE
/* What type of chip is used for I2C communication
0 : PCF8574 or PCF8574A or compatible chips.
1 : MCP23017
#define UI_DISPLAY_I2C_CHIPTYPE 0
// 0x40 till 0x4e for PCF8574, 0x40 for the adafruid RGB shield, 0x40 - 0x4e for MCP23017
// Official addresses have a value half as high!
#define UI_DISPLAY_I2C_ADDRESS 0x4e
// For MCP 23017 define which pins should be output
#define UI_DISPLAY_I2C_OUTPUT_PINS 65504
// Set the output mask that is or'd over the output data. This is needed to activate
// a backlight switched over the I2C.
// The adafruit RGB shields enables a light if the bit is not set. Bits 6-8 are used for backlight.
#define UI_DISPLAY_I2C_OUTPUT_START_MASK 0
// For MCP which inputs are with pullup. 31 = pins 0-4 for adafruid rgb shield buttons
#define UI_DISPLAY_I2C_PULLUP 31
/* How fast should the I2C clock go. The PCF8574 work only with the lowest setting 100000.
A MCP23017 can run also with 400000 Hz */
#define UI_I2C_CLOCKSPEED 100000L
Define the pin
#if UI_DISPLAY_TYPE == DISPLAY_I2C // I2C Pin configuration
#define UI_DISPLAY_RS_PIN _BV(4)
#define UI_DISPLAY_RW_PIN _BV(5)
#define UI_DISPLAY_ENABLE_PIN _BV(6)
#define UI_DISPLAY_D0_PIN _BV(0)
#define UI_DISPLAY_D1_PIN _BV(1)
#define UI_DISPLAY_D2_PIN _BV(2)
#define UI_DISPLAY_D3_PIN _BV(3)
#define UI_DISPLAY_D4_PIN _BV(0)
#define UI_DISPLAY_D5_PIN _BV(1)
#define UI_DISPLAY_D6_PIN _BV(2)
#define UI_DISPLAY_D7_PIN _BV(3)
// uncomment if your using led to indicated the bed is hot
//#define UI_I2C_HEATBED_LED    _BV(8)
// uncomment if your using led to indicated the extruder is hot
//#define UI_I2C_HOTEND_LED     _BV(7)
// uncomment if your using led to indicated the FAN is on
//#define UI_I2C_FAN_LED        _BV(6)
// Pins for adafruid RGB shield
/*#define UI_DISPLAY_RS_PIN _BV(15)
#define UI_DISPLAY_RW_PIN _BV(14)
#define UI_DISPLAY_ENABLE_PIN _BV(13)
#define UI_DISPLAY_D0_PIN _BV(12)
#define UI_DISPLAY_D1_PIN _BV(11)
#define UI_DISPLAY_D2_PIN _BV(10)
#define UI_DISPLAY_D3_PIN _BV(9)
#define UI_DISPLAY_D4_PIN _BV(12)
#define UI_DISPLAY_D5_PIN _BV(11)
#define UI_DISPLAY_D6_PIN _BV(10)
#define UI_DISPLAY_D7_PIN _BV(9)*/
#else // Direct display connections
#define UI_DISPLAY_RS_PIN    46
#define UI_DISPLAY_RW_PIN   -1
#define UI_DISPLAY_ENABLE_PIN 47
#define UI_DISPLAY_D0_PIN   -1
#define UI_DISPLAY_D1_PIN   -1
#define UI_DISPLAY_D2_PIN   -1
#define UI_DISPLAY_D3_PIN   -1
#define UI_DISPLAY_D4_PIN   44
#define UI_DISPLAY_D5_PIN   -1
#define UI_DISPLAY_D6_PIN   -1
#define UI_DISPLAY_D7_PIN   -1
#define UI_DELAYPERCHAR      350
#endif
/** \brief Are some keys connected?
0 = No keys attached - disables also menu
1 = Some keys attached
#define UI_HAS_KEYS 1
/** \brief Is a back key present.
If you have menus enabled, you need a method to leave it. If you have a back key, you can always go one level higher.
Without a back key, you need to navigate to the back entry in the menu. Setting this value to 1 removes the back entry.
#define UI_HAS_BACK_KEY 0
/* Then you have the next/previous keys more like up/down keys, it may be more intuitive to change the direction you skip through the menus.
If you set it to true, next will go to previous menu instead of the next menu.
#define UI_INVERT_MENU_DIRECTION 0
/** Uncomment this, if you have keys connected via i2c to a PCF8574 chip. */
//#define UI_HAS_I2C_KEYS
// Do you have a I2C connected encoder?
#define UI_HAS_I2C_ENCODER 0
// Under which address can the key status requested. This is the address of your PCF8574 where the keys are connected.
// If you use a MCP23017 the address from display is used also for keys.
#define UI_I2C_KEY_ADDRESS 0x40
#ifdef UI_MAIN
                      Key definitions
The firmware is very flexible regarding your input methods. You can use one
or more of the predefined key macros, to define a mapper. If no matching mapper
is available, you can add you c-code for mapping directly into the keyboard
routines. The predefined macros do the same, just hiding the code behind it.
For each key, two seperate parts must be defined. The first is the initialization
which must be added inside uiInitKeys() and the second ist a testing routine.
These come into uiCheckKeys() or uiCheckSlowKeys() depending on the time needed
for testing. If you are in doubt, put it in uiCheckSlowKeys().
uiInitKeys() is called from an interrupt controlling the extruder, so only
fast tests should be put there.
The detect methods need an action identifier. A list of supported ids is found
at the beginning of ui.h It's best to use the symbol name, in case the value changes.
1. Simple push button connected to gnd if closed on a free arduino pin
    init -> UI_KEYS_INIT_BUTTON_LOW(pinNumber);
    detect -> UI_KEYS_BUTTON_LOW(pinNumber,action);
2. Simple push button connected to 5v if closed on a free arduino pin
    init -> UI_KEYS_INIT_BUTTON_HIGH(pinNumber);
    detect -> UI_KEYS_BUTTON_HIGH(pinNumber,action);
3. Click encoder, A/B connected to gnd if closed.
    init -> UI_KEYS_INIT_CLICKENCODER_LOW(pinA,pinB);
    detect -> UI_KEYS_CLICKENCODER_LOW(pinA,pinB);
         or   UI_KEYS_CLICKENCODER_LOW_REV(pinA,pinB); // reverse direction
    If you can move the menu cursor without a click, just be adding some force in one direction,
    toggle the _REV with non _REV and toggle pins.
    If the direction is wrong, toggle _REV with non _REV version.
    For the push button of the encoder use 1.
4. Click encoder, A/B connected to 5V if closed.
    init -> UI_KEYS_INIT_CLICKENCODER_HIGH(pinA,pinB);
    detect -> UI_KEYS_CLICKENCODER_HIGH(pinA,pinB);
         or   UI_KEYS_CLICKENCODER_HIGH_REV(pinA,pinB); // reverse direction
    For the push button of the encoder use 2.
5. Maxtrix keyboard with 1-4 rows and 1-4 columns.
    init -> UI_KEYS_INIT_MATRIX(r1,r2,r3,r4,c1,c2,c3,c4);
    detect -> UI_KEYS_MATRIX(r1,r2,r3,r4,c1,c2,c3,c4);
    In addition you have to set UI_MATRIX_ACTIONS to match your desired actions.
------- Keys connected via I2C -------------
All keys and the buzzer if present must be on a connected to a single PCF8574 chip!
As all I2C request take time, they belong all in uiCheckSlowKeys.
Dont use the pin ids but instead _BV(pinNumber0_7) as pin id. 0 = First pin
6. Click encoder, A/B connected to gnd if closed.
    init -> not needed, but make sure UI_HAS_I2C_KEY is not commented out.
    detect -> UI_KEYS_I2C_CLICKENCODER_LOW(pinA,pinB);
         or   UI_KEYS_I2C_CLICKENCODER_LOW_REV(pinA,pinB); // reverse direction
    For the push button of the encoder use 7.
    NOTICE: The polling frequency is limited, so only slow turns are captured correct!
7. Simple push button connected to gnd if closed via I2C on a PCF8574
    detect -> UI_KEYS_I2C_BUTTON_LOW(pinNumber,action);
-------- Some notes on actions -------------
There are three kinds of actions.
Type 1: Immediate actions - these are execute and forget actions like home/pre-heat
Type 2: Parameter change action - these change the mode for next/previous keys. They are valid
        until a new change action is initiated or the action is finished with ok button.
Type 3: Show menu action. These actions have a _MENU_ in their name. If they are executed, a new
        menu is pushed on the menu stack and you see the menu. If you assign these actions directly
        to a key, you might not want this pushing behaviour. In this case add UI_ACTION_TOPMENU to the
        action, like UI_ACTION_TOPMENU+UI_ACTION_MENU_XPOSFAST. That will show the menu as top-menu
        closing all othe submenus that were open.
// Use these codes for key detect. The main menu will show the pressed action in the lcd display.
// after that assign the desired codes.
//#define UI_MATRIX_ACTIONS {2000,2001,2002,2003,2004,2005,2006,2007,2008,2009,2010,2011,2012,2013,2014,2015}
// Define your matrix actions
#define UI_MATRIX_ACTIONS {UI_ACTION_HOME_ALL, UI_ACTION_TOP_MENU,       UI_ACTION_SET_ORIGIN,      UI_ACTION_NEXT,\
                           UI_ACTION_HOME_Z,   UI_ACTION_MENU_ZPOS,      UI_ACTION_COOLDOWN,        UI_ACTION_OK,\
                           UI_ACTION_HOME_Y,   UI_ACTION_MENU_YPOSFAST,  UI_ACTION_PREHEAT_ABS,     UI_ACTION_PREVIOUS,\
                           UI_ACTION_HOME_X,   UI_ACTION_MENU_XPOSFAST,  UI_ACTION_DISABLE_STEPPER, UI_ACTION_BACK}
#ifdef UI_MATRIX_ACTIONS
const int matrixActions[] PROGMEM = UI_MATRIX_ACTIONS;
#endif
void uiInitKeys() {
#if UI_HAS_KEYS!=0
  UI_KEYS_INIT_CLICKENCODER_LOW(50,52); // click encoder on pins 50 and 52. Phase is connected with gnd for signals.
  UI_KEYS_INIT_BUTTON_LOW(48); // push button, connects gnd to pin
  //UI_KEYS_INIT_BUTTON_LOW(5);
  //UI_KEYS_INIT_BUTTON_LOW(6);
  //UI_KEYS_INIT_BUTTON_LOW(11);
  //UI_KEYS_INIT_BUTTON_LOW(42);
//  UI_KEYS_INIT_CLICKENCODER_LOW(47,45); // click encoder on pins 47 and 45. Phase is connected with gnd for signals.
//  UI_KEYS_INIT_BUTTON_LOW(43); // push button, connects gnd to pin
//  UI_KEYS_INIT_MATRIX(32,47,45,43,41,39,37,35);
#endif
void uiCheckKeys(int &action) {
#if UI_HAS_KEYS!=0
 UI_KEYS_CLICKENCODER_LOW_REV(50,52); // click encoder on pins 50 and 52. Phase is connected with gnd for signals.
 UI_KEYS_BUTTON_LOW(48,UI_ACTION_OK); // push button, connects gnd to pin
 //UI_KEYS_BUTTON_LOW(5,UI_ACTION_NEXT); // push button, connects gnd to pin
 //UI_KEYS_BUTTON_LOW(6,UI_ACTION_PREVIOUS); // push button, connects gnd to pin
 //UI_KEYS_BUTTON_LOW(11,UI_ACTION_BACK); // push button, connects gnd to pin
 //UI_KEYS_BUTTON_LOW(42,UI_ACTION_SD_PRINT ); // push button, connects gnd to pin
//  UI_KEYS_CLICKENCODER_LOW_REV(47,45); // click encoder on pins 47 and 45. Phase is connected with gnd for signals.
//  UI_KEYS_BUTTON_LOW(43,UI_ACTION_OK); // push button, connects gnd to pin
#endif
inline void uiCheckSlowEncoder() {
#if defined(UI_HAS_I2C_KEYS) && UI_HAS_KEYS!=0
#if UI_DISPLAY_I2C_CHIPTYPE==0
  HAL::i2cStartWait(UI_I2C_KEY_ADDRESS+I2C_READ);
  uint8_t keymask = HAL::i2cReadNak(); // Read current key mask
#endif
#if UI_DISPLAY_I2C_CHIPTYPE==1
    HAL::i2cStartWait(UI_DISPLAY_I2C_ADDRESS+I2C_WRITE);
    HAL::i2cWrite(0x12); // GIOA
    HAL::i2cStop();
    HAL::i2cStartWait(UI_DISPLAY_I2C_ADDRESS+I2C_READ);
    unsigned int keymask = HAL::i2cReadAck();
    keymask = keymask + (HAL::i2cReadNak()<<8);
#endif
  HAL::i2cStop();
  // Add I2C click encoder tests here, all other i2c tests and a copy of the encoder test belog in uiCheckSlowKeys
  UI_KEYS_I2C_CLICKENCODER_LOW_REV(_BV(2),_BV(0)); // click encoder on pins 0 and 2. Phase is connected with gnd for signals.
#endif
void uiCheckSlowKeys(int &action) {
#endif
    HAL::i2cWrite(0x12); // GPIOA
    HAL::i2cStop();
#endif
    HAL::i2cStop();
    // Add I2C key tests here
    UI_KEYS_I2C_BUTTON_LOW(_BV(1),UI_ACTION_OK); // push button, connects gnd to pin
    UI_KEYS_I2C_BUTTON_LOW(_BV(3),UI_ACTION_BACK); // push button, connects gnd to pin
    UI_KEYS_I2C_BUTTON_LOW(_BV(4),UI_ACTION_MENU_QUICKSETTINGS+UI_ACTION_TOPMENU); // push button, connects gnd to pin
    UI_KEYS_I2C_BUTTON_LOW(_BV(5),UI_ACTION_MENU_EXTRUDER+UI_ACTION_TOPMENU); // push button, connects gnd to pin
    UI_KEYS_I2C_BUTTON_LOW(_BV(6),UI_ACTION_MENU_POSITIONS+UI_ACTION_TOPMENU); // push button, connects gnd to pin
  // Button handling for the Adafruit RGB shild
    UI_KEYS_I2C_BUTTON_LOW(4,UI_ACTION_PREVIOUS); // Up button
    UI_KEYS_I2C_BUTTON_LOW(8,UI_ACTION_NEXT); // down button
    UI_KEYS_I2C_BUTTON_LOW(16,UI_ACTION_BACK); // left button
    UI_KEYS_I2C_BUTTON_LOW(2,UI_ACTION_OK); // right button
    UI_KEYS_I2C_BUTTON_LOW(1,UI_ACTION_MENU_QUICKSETTINGS);  //Select button
  // ----- End RGB shield ----------
#endif
  //UI_KEYS_MATRIX(32,47,45,43,41,39,37,35);
#endif
#endif
Re: Radds - Graficzny wyświetlacz
Postautor: Sławek » 05 lip 2015, 18:26
Zmień parametr w configuration.h :
na :
#define UI_LANGUAGE 1000
i wgraj ponownie firmware do arduino ;)
lub dodaj w uilang.h :
#if UI_LANGUAGE==1001
#define UI_TEXT_ON               "Wlacz"
#define UI_TEXT_OFF              "Wylacz"
#define UI_TEXT_NA               "N/A" // Output for not available
#define UI_TEXT_YES              "Tak"
#define UI_TEXT_NO               "Nie"
#define UI_TEXT_SEL              "\003"
#define UI_TEXT_NOSEL            "\004"
#define UI_TEXT_PRINT_POS        "Drukowanie ..."
#define UI_TEXT_PRINTING         "Drukowanie"
#define UI_TEXT_IDLE             "W trakcie"
#define UI_TEXT_NOSDCARD         "Brak carty SD"
#define UI_TEXT_ERROR            "**** Blad ****"
#define UI_TEXT_BACK             "Powrot \001"
#define UI_TEXT_QUICK_SETTINGS   "Szybkie ustawienia"
#define UI_TEXT_CONFIGURATION    "Konfiguracja"
#define UI_TEXT_POSITION         "Pozycja"
#define UI_TEXT_EXTRUDER         "Extruder"
#define UI_TEXT_SD_CARD          "Karta SD"
#define UI_TEXT_DEBUGGING        "Debugging"
#define UI_TEXT_HOME_ALL         "Home All"
#define UI_TEXT_HOME_X           "Home X"
#define UI_TEXT_HOME_Y           "Home Y"
#define UI_TEXT_HOME_Z           "Home Z"
#define UI_TEXT_PREHEAT_PLA      "Grzanie PLA"
#define UI_TEXT_PREHEAT_ABS      "Grzanie ABS"
#define UI_TEXT_COOLDOWN         "Studzenie"
#define UI_TEXT_SET_TO_ORIGIN    "Ustaw na orygin."
#define UI_TEXT_DISABLE_STEPPER  "Blokada krokow"
#define UI_TEXT_X_POSITION       "X Pozycja"
#define UI_TEXT_X_POS_FAST       "X Poz. szybko"
#define UI_TEXT_Y_POSITION       "Y Pozycja"
#define UI_TEXT_Y_POS_FAST       "Y Poz. szybko"
#define UI_TEXT_Z_POSITION       "Z Pozycja"
#define UI_TEXT_Z_POS_FAST       "Z Poz. szybko"
#define UI_TEXT_E_POSITION       "Extr. pozycja"
#define UI_TEXT_BED_TEMP         "Temp stolu: %Eb\002C"
#define UI_TEXT_EXTR0_TEMP       "Temp. 1:  %E0\002C"
#define UI_TEXT_EXTR1_TEMP       "Temp. 2:  %E1\002C"
#define UI_TEXT_EXTR2_TEMP       "Temp. 2:  %E2\002C"
#define UI_TEXT_EXTR0_OFF        "Extruder 1 wyl."
#define UI_TEXT_EXTR1_OFF        "Extruder 2 wyl."
#define UI_TEXT_EXTR2_OFF        "Extruder 3 wyl"
#define UI_TEXT_EXTR0_SELECT     "%X0 Wybierz Extr. 1"
#define UI_TEXT_EXTR1_SELECT     "%X1 Wybierz Extr. 2"
#define UI_TEXT_EXTR2_SELECT     "%X1 Wybierz Extr. 3"
#define UI_TEXT_EXTR_ORIGIN      "Ustaw orygin."
#define UI_TEXT_PRINT_X          "Druk X:%ax"
#define UI_TEXT_PRINT_Y          "Druk Y:%ay"
#define UI_TEXT_PRINT_Z          "Druk Z:%az"
#define UI_TEXT_PRINT_Z_DELTA    "Druk:%az"
#define UI_TEXT_MOVE_X           "Przesun X:%aX"
#define UI_TEXT_MOVE_Y           "Przesun Y:%aY"
#define UI_TEXT_MOVE_Z           "Przesun Z:%aZ"
#define UI_TEXT_MOVE_Z_DELTA     "Przesun:%aZ"
#define UI_TEXT_JERK             "Jerk:%aj"
#define UI_TEXT_ZJERK            "Z-Jerk:%aJ"
#define UI_TEXT_ACCELERATION     "Przyspieszenie"
#define UI_TEXT_STORE_TO_EEPROM  "Zapisz do EEPROM"
#define UI_TEXT_LOAD_EEPROM      "Laduj z EEPROM"
#define UI_TEXT_DBG_ECHO         "Echo   :%do"
#define UI_TEXT_DBG_INFO         "Info   :%di"
#define UI_TEXT_DBG_ERROR        "Bledy :%de"
#define UI_TEXT_DBG_DRYRUN       "Ruch na sucho:%dd"
#define UI_TEXT_OPS_OFF          "%O0 OPS Wyl."
#define UI_TEXT_OPS_CLASSIC      "%O1 OPS Klasycz."
#define UI_TEXT_OPS_FAST         "%O2 OPS Szybk."
#define UI_TEXT_OPS_RETRACT      "Retrakcja :%Or"
#define UI_TEXT_OPS_BACKSLASH    "Wycofanie :%Ob"
#define UI_TEXT_OPS_MINDIST      "Min.dyst:%Od"
#define UI_TEXT_OPS_MOVE_AFTER   "Przesun po:%Oa"
#define UI_TEXT_ANTI_OOZE        "Anti Ooze"
#define UI_TEXT_PRINT_FILE       "Drukuj plik"
#define UI_TEXT_PAUSE_PRINT      "Pauza druk."
#define UI_TEXT_CONTINUE_PRINT   "kontynuacja druk."
#define UI_TEXT_UNMOUNT_CARD     "Odmontowana karta"
#define UI_TEXT_MOUNT_CARD       "Zamontowana karta"
#define UI_TEXT_DELETE_FILE      "usun plik"
#define UI_TEXT_FEEDRATE         "Feedrate"
#define UI_TEXT_FEED_MAX_X       "Max X:%fx"
#define UI_TEXT_FEED_MAX_Y       "Max Y:%fy"
#define UI_TEXT_FEED_MAX_Z       "Max Z:%fz"
#define UI_TEXT_FEED_MAX_Z_DELTA "Max:%fz"
#define UI_TEXT_FEED_HOME_X      "Home X:%fX"
#define UI_TEXT_FEED_HOME_Y      "Home Y:%fY"
#define UI_TEXT_FEED_HOME_Z      "Home Z:%fZ"
#define UI_TEXT_FEED_HOME_Z_DELTA "Home:%fZ"
#define UI_TEXT_ACTION_XPOSITION4 "X:%x0 mm","Min endstop:%sx","Max endstop:%sX",""
#define UI_TEXT_ACTION_YPOSITION4 "Y:%x1 mm","Min endstop:%sy","Max endstop:%sY",""
#define UI_TEXT_ACTION_ZPOSITION4 "Z:%x2 mm","Min endstop:%sz","Max endstop:%sZ",""
#define UI_TEXT_ACTION_XPOSITION_FAST4 "X:%x0 mm","Min endstop:%sx","Max endstop:%sX",""
#define UI_TEXT_ACTION_YPOSITION_FAST4 "Y:%x1 mm","Min endstop:%sy","Max endstop:%sY",""
#define UI_TEXT_ACTION_ZPOSITION_FAST4 "Z:%x2 mm","Min endstop:%sz","Max endstop:%sZ",""
#define UI_TEXT_ACTION_EPOSITION_FAST2 "E:%x3 mm","1 click = 1 mm"
#define UI_TEXT_ACTION_XPOSITION2 "X:%x0 mm","Min:%sx Max:%sX"
#define UI_TEXT_ACTION_YPOSITION2 "Y:%x1 mm","Min:%sy Max:%sY"
#define UI_TEXT_ACTION_ZPOSITION2 "Z:%x2 mm","Min:%sz Max:%sZ"
#define UI_TEXT_ACTION_XPOSITION_FAST2 "X:%x0 mm","Min:%sx Max:%sX"
#define UI_TEXT_ACTION_YPOSITION_FAST2 "Y:%x1 mm","Min:%sy Max:%sY"
#define UI_TEXT_ACTION_ZPOSITION_FAST2 "Z:%x2 mm","Min:%sz Max:%sZ"
#define UI_TEXT_FANSPEED          "Predk. went."
#define UI_TEXT_ACTION_FANSPEED   "Predk. went. :%Fs%%%"
#define UI_TEXT_FAN_OFF           "Wylacz went."
#define UI_TEXT_FAN_25            "Ustaw went. 25%%%"
#define UI_TEXT_FAN_50            "ustaw went. 50%%%"
#define UI_TEXT_FAN_75            "Ustaw went. 75%%%"
#define UI_TEXT_FAN_FULL          "Ustaw went. pelny"
#define UI_TEXT_STEPPER_INACTIVE  "Siliniki niekatywne"
#define UI_TEXT_STEPPER_INACTIVE2 "Dis. After:%is","[s] 0=Off"
#define UI_TEXT_POWER_INACTIVE    "Max. Inactive"
#define UI_TEXT_POWER_INACTIVE2   "Dis. After:%ip","[s] 0=Off"
#define UI_TEXT_GENERAL           "Glowne"
#define UI_TEXT_BAUDRATE          "Baudrate:%oc"
#define UI_TEXT_EXTR_STEPS        "Steps/MM:%Se"
#define UI_TEXT_EXTR_START_FEED   "Start FR:%Xf"
#define UI_TEXT_EXTR_MAX_FEED     "Max FR:%XF"
#define UI_TEXT_EXTR_ACCEL        "Accel:%XA"
#define UI_TEXT_EXTR_WATCH        "Stab.Time:%Xw"
#define UI_TEXT_EXTR_ADVANCE_L    "Advance lin:%Xl"
#define UI_TEXT_EXTR_ADVANCE_K    "Advance quad:%Xa"
#define UI_TEXT_EXTR_MANAGER      "Control:%Xh"
#define UI_TEXT_EXTR_PGAIN        "DT/PID P:%Xp"
#define UI_TEXT_EXTR_IGAIN        "PID I:%Xi"
#define UI_TEXT_EXTR_DGAIN        "PID D:%Xd"
#define UI_TEXT_EXTR_DMIN         "Drive Min:%Xm"
#define UI_TEXT_EXTR_DMAX         "Drive Max:%XM"
#define UI_TEXT_EXTR_PMAX         "PID Max:%XD"
#define UI_TEXT_EXTR_XOFF         "X-Offset:%Xx"
#define UI_TEXT_EXTR_YOFF         "Y-Offset:%Xy"
#define UI_TEXT_STRING_HM_BANGBANG "BangBang"
#define UI_TEXT_STRING_HM_PID     "PID"
#define UI_TEXT_STRING_ACTION     "Akcja:%la"
#define UI_TEXT_HEATING_EXTRUDER  "Podgrzewam Extruder"
#define UI_TEXT_HEATING_BED       "Podgrzewam stol"
#define UI_TEXT_KILLED            "Zatrzymany"
#define UI_TEXT_STEPPER_DISABLED  "Silniki zatrzymane"
#define UI_TEXT_EEPROM_STORED     "Konfoguracja","zapisana w EEPROM"
#define UI_TEXT_EEPROM_LOADED     "Konfiguracja","zaladowana z EEPROM"
#define UI_TEXT_UPLOADING         "Wysylanie..."
#define UI_TEXT_PAGE_BUFFER       "Buffer:%oB"
#define UI_TEXT_PAGE_EXTRUDER     " E:%ec/%Ec\002C\176%oC"
#define UI_TEXT_PAGE_EXTRUDER1     "E1:%e0/%E0\002C\176%o0"
#define UI_TEXT_PAGE_EXTRUDER2     "E2:%e1/%E1\002C\176%o1"
#define UI_TEXT_PAGE_EXTRUDER3     "E3:%e2/%E2\002C\176%o2"
#define UI_TEXT_PAGE_BED          " B:%eb/%Eb\002C\176%ob"
#define UI_TEXT_SPEED_MULTIPLY    "Speed Mul.:%om%%%"
#define UI_TEXT_FLOW_MULTIPLY     "Flow Mul.:%of%%%"
#define UI_TEXT_EXTR_WAIT_RETRACT_TEMP  "Oczekiw. na temp.%XT\002C"
#define UI_TEXT_EXTR_WAIT_RETRACT_UNITS "Wait Units:%XUmm"
#define UI_TEXT_PRINTER_READY    "Drukarka gotowa."
// Printtime output gets aggregated like <Days_5gisgits>UI_TEXT_PRINTTIME_DAYS<Hours>UI_TEXT_PRINTTIME_HOURS<Minutes>UI_TEXT_PRINTTIME_MINUTES
// ___88 days 12:45
#define UI_TEXT_PRINTTIME_DAYS   " dni "
#define UI_TEXT_PRINTTIME_HOURS  ":"
#define UI_TEXT_PRINTTIME_MINUTES ""
#define UI_TEXT_PRINT_TIME     "czas drukowania"
#define UI_TEXT_PRINT_FILAMENT "Wydrukowany filament"
#define UI_TEXT_POWER            "ATX zasilanie wl/wyl"
#define UI_TEXT_STRING_HM_DEADTIME     "Dead Time"
#define UI_TEXT_STRING_HM_SLOWBANG     "SlowBang"
#define UI_TEXT_STOP_PRINT "Zatrzymanie druku"
#endif
i ustaw #define UI_LANGUAGE 1001
a następnie wgraj firmware do arduino, będziesz miał po polsku ;)
Pozdr
lukasz51
Postautor: lukasz51 » 06 lip 2015, 0:23
No niestety, ale dalej to samo, na wyświetlaczu pojawia się śnieg lub krzaki. Gdy kręcę enkoderem widać, że coś się zmienia, ale dalej to krzaki. Dodam, że ten wyświetlacz działał bardzo dobrze pod ramps 1.4.
