Wgrywanie Marlin-a do Sanguinololu 1.3a
Re: Wgrywanie Marlin-a do Sanguinololu 1.3a
Postautor: Fabrykator.pl » 28 gru 2012, 17:09
sprawdź, czy w Arduino, w pliku boards.txt (hardware) masz dopisaną atmegę 1284p
CZOPER
Postautor: CZOPER » 28 gru 2012, 18:20
Jest .
To jest Arduino-0023
Paczka Sanguinololu i Marlin ten co otrzymałem w załącznikach (w tym temacie) ;)
atmega644.name=Sanguino W/ ATmega644
atmega644.upload.protocol=stk500
atmega644.upload.maximum_size=63488
atmega644.upload.speed=38400
atmega644.bootloader.low_fuses=0xFF
atmega644.bootloader.high_fuses=0xDC
atmega644.bootloader.extended_fuses=0xFD
atmega644.bootloader.path=atmega644p
atmega644.bootloader.file=ATmegaBOOT_644P.hex
atmega644.bootloader.unlock_bits=0x3F
atmega644.bootloader.lock_bits=0x0F
atmega644.build.mcu=atmega644p
atmega644.build.f_cpu=16000000L
atmega644.build.core=arduino
atmega12848m.name=Sanguino W/ ATmega1284p 8mhz
atmega12848m.upload.protocol=stk500
atmega12848m.upload.maximum_size=131072
atmega12848m.upload.speed=19200
atmega12848m.bootloader.low_fuses=0xFD
atmega12848m.bootloader.high_fuses=0x9A
atmega12848m.bootloader.extended_fuses=0xFF
atmega12848m.bootloader.path=atmega
atmega12848m.bootloader.file=ATmegaBOOT_168_atmega1284p_8m.hex
atmega12848m.bootloader.unlock_bits=0x3F
atmega12848m.bootloader.lock_bits=0x0F
atmega12848m.build.mcu=atmega1284p
atmega12848m.build.f_cpu=8000000L
atmega12848m.build.core=arduino
atmega1284.name=Sanguino W/ ATmega1284p 16mhz
atmega1284.upload.protocol=stk500
atmega1284.upload.maximum_size=131072
atmega1284.upload.speed=57600
atmega1284.bootloader.low_fuses=0xFF
atmega1284.bootloader.high_fuses=0x99
atmega1284.bootloader.extended_fuses=0xFF
atmega1284.bootloader.path=atmega
atmega1284.bootloader.file=ATmegaBOOT_168_atmega1284p.hex
atmega1284.bootloader.unlock_bits=0x3F
atmega1284.bootloader.lock_bits=0x0F
atmega1284.build.mcu=atmega1284p
atmega1284.build.f_cpu=16000000L
atmega1284.build.core=arduino
Jestem oazą spokoju. Pi*, ku*, zaj* wyluzowanym kwiatem lotosu na tafli jeziora. Prawdę mówiąc jestem wyluzowany jak wagon pełen pi*, medytujących tybetańskich mnichów.
Postautor: Fabrykator.pl » 28 gru 2012, 18:26
Może instrukcja kolegi z drugiego forum będzie bardziej przejrzysta. Tam też acc podłączył pliki
http://reprapforum.pl/atmega-1284p-howto-t243.html
Postautor: acc » 28 gru 2012, 19:12
z małą uwagą że moje wpisy dotyczą bootloadera na 250,000 a nie standardowego.
CZOPER
Postautor: CZOPER » 28 gru 2012, 19:15
Co bym nie robił, jakich plików bym nie użył, cały czas błąd
CZOPER pisze:[b]
Binary sketch size: 93922 bytes (of a 131072 byte maximum)
avrdude: AVR Part "atmega1284p" not found.
Valid parts are:
m6450 = ATMEGA6450 [C:\Users\CZOPER\Desktop\arduino-0023\arduino-0023\hardware/tools/avr/etc/avrdude.conf:11732]
m3250 = ATMEG....
Do tego cały czas mam niezainicjalizowany wyświetlacz :(
Podłączyłem tak jak w tym linku http://blog.think3dprint3d.com/2012/06/panelolu-in-depth.html
Re: Odp: Wgrywanie Marlin-a do Sanguinololu 1.3a
Postautor: acc » 28 gru 2012, 19:45
Użyj nowszego avrdude o którym napisałem w linku podanym przez u-design.
skawikk
Postautor: skawikk » 28 gru 2012, 19:50
Nowszy AVRDude pomaga na wszystko;)
A nie prościej? Wrzucę na chomika zaraz spakowane Arduino ze wszystkimi plikami podmienionymi.
M.
//edit//
Z jakąś godzinę będzie do pobrania STĄD
Arduino 0.2.3 z nowym AVRdude i plikami do sanginololu i atmegi 1280P na bootloader 250k.
FabLab Kielce
Dni Druku
- Masz na to wpływ?
- ?! Nie..
Postautor: acc » 28 gru 2012, 20:15
skawikk nie pamiętam jak masz, czy u Ciebie w boards.txt są dwie sekcje dla 1284p? Dla bootloadera @250000 i drugi dla zwykłego? Bo jak kolega nie ma bootloadera 250000 to będzie musiał i tak przeedytować boards.txt.
skawikk
Postautor: skawikk » 28 gru 2012, 20:19
Mam ten z dwiema sekcjami;)
FabLab Kielce
Dni Druku
- Masz na to wpływ?
- ?! Nie..
CZOPER
Postautor: CZOPER » 28 gru 2012, 20:32
Czekam z niecierpliwością na "chomika" ;)
Wróć do „Sanguinololu”
